You can determine the database used by the SPBM multicast module by using the following procedure.
Show the SPBM multicast database:
Switch(config)#show isis spbm ip-multicast-route ================================================================================ SPBM IP-MULTICAST FIB ENTRY INFO ================================================================================ Source Group Data ISID BVLAN Source-BEB -------------------------------------------------------------------------------- 192.2.0.1 233.252.0.246 16000001 101 EVP -------------------------------------------------------------------------------- Total Number of SPBM IP MULTICAST ROUTE Entries: 1 --------------------------------------------------------------------------------
The following table defines parameters for the show isis spbm ip-multicast-route command.
Variable |
Value |
all |
Displays all IP Multicast over Fabric Connect route information. |
detail |
Displays detailed IP Multicast over Fabric Connect route information. |
group {A.B.C.D} source {A.B.C.D} |
Displays information on the group IP address for the IP Multicast over Fabric Connect route. If you select source it will also display the source IP address. |
vlan <2–4059> |
Displays IP Multicast over Fabric Connect route information by VLAN. |
vrf WORD<0–16> |
Displays IP Multicast over Fabric Connect route information by VRF. |
vsn-isid <1–16777215> |
Displays IP Multicast over Fabric Connect route information by I-SID. |
